hey guys, im still having problems with my car. right now ive got no spark and my injectors are not firing at all. I had a blown cap in my ecu, i got that replaced early last week at ATS in denton. Then i found a broken wire on my harness near the connector, it was the very far bottom right red wire on the far right ecu connector, which my friend said is ignition power to the ecu, well i re-soldered that together. and i still have nothing. i used my test light and im not getting power to the far two wires on that connector. i get power to the wires right next to them but not at the two at the far side. i also checked and ive got power to the injectors and the coils when i have the key turned. i changed out the cam position sensors and the crank position sensor, and my ignitor is good, i tested that on a friends MKIV and he started and drove on it. i also checked all my fuses and they are good as well. im stumped over it, im not really electrically inclined at all, so if you guys might know what it is please chime in, if i cant figure it out this weekend its gonna go to a shop to get whatever the problem is fixed.
thanks guys
thanks guys
