Ok so i just finished putting everything back together, but now i have a new problem. When i connected the negative terminal on the battery, i'm getting no power to the car whatsoever. I mean none. The instrument cluster doesn't work, the dome light doesn't work, no spark, no crank, no nothing. SO i figure i must have messed up a ground cable or a power cable somewhere.
It's a brand new battery so that's out of the question.
I've rechecked and reconnected the starter wires and the alternator wires (plus i didn't disconnect the starter wire, only the plug so that i could remove the harness)
I've connected all of the connectors on the wire harness to their respective sensors.
I grounded the brown/white cables that run next to the starter onto the intake manifold.
The battery is grounded.
SO my question is, where should i start looking because i've checked everything i can think of. It's just kind of bizzare to me that i'm not getting any juice.
Help would be appreciated, and quick. I'm leaving tonight for school :1zhelp:
