no crank after new starter.
nthilavan
booster
Dec 31, 2010
56
SE Portland
so my starter went out on me the other day at work.. got some coworkers to help me push start and got it home pulled the starter and put new one.. first try started right up.. then turned it off and tried again and nothing..checked for codes and none came up..took start out again went back to auto zone got another one and put in.. and nothing no crank.. havent tried push start cause its just me.. but any ideas.. need help and fast..
8,898
You really bought a new(not really) starter from the worst place without any testing?
1. Your new starter could be bad
2. You have a igntion control problem; the key applies switched power to the relay circuit, the main power wire could be loose on the stud, bad battery (loose plate)
D.J.T.
877
Arkansas, United States
NEVER EVER go to Autozone... The faggots at my local autozone will not exchange or do warranty. But when you buy the part they tell you so & so about the warranty. I know many people that work at Advance Auto or Oreilly's that use to work at Autozone. Why? same shit, they didn't like that B.S. & they told me when they turned down the warranty the manager would even pat them on the back & say "Good Job" & most of the workers are cool with that...... FUCK AUTOZONE!!
Oreilly's or NAPA are the best options other than Dealership
nthilavan
booster
Dec 31, 2010
56
SE Portland
never seem to have a problem there. they always replace anything thats doesnt work for me. battery is new. seems like its a bigger problem just got my windshield replace and speedometer went out and now car wont start..ill check to day and see if power is running to the starter
92nsx
2,957
Clearwater, MN
Dose it even click?
Auto or manual ? (Neutral switch / clutch switch )
Check The blue wire (about 14-12 gauge wire) that goes to the starter. the push on tabs can get bent ezly. In that fact make sure that wire isnt broken.
Battery not dead correct.
Do you own a multimeter? Check voltage on starter wire (blue one above with some one holding the key to start).
Check Ground from battery to block - make sure there CLEAN and tight or even broken.
Check power (12+) going from battery to starter.
nthilavan
booster
Dec 31, 2010
56
SE Portland
its manual.. power from battery to starter is good. i own multi meter but dont know how to use it.. was a gift. ground from battery to block is solid..
im gonna have a friend over later today to get a push and see if it starts like that.
---------- Post added at 03:42 PM ---------- Previous post was at 03:36 PM ----------
its really hard to find the correct wiring cause the owner before me has everything cut and hanging all over the place.. been looking for new harness... almost had one but got sniped at last second of the bid
Oct 11, 2005
3,819
20
Thousand Oaks, CA
Replace the ECU:aigo: Might as well blame the new windshield!
You need to learn how to use the multimeter to diagnose electrical problems, or find someone to do it for you. No other approach is going to work well.
JStoked
646
Edmond, Oklahoma, United States
Wow really!!! MAne you need to learn to use one:icon_bigg
ihateu3
51
Ohio
Whos gay ass black truck in the background? Damn those rims are 90s blingtacious hideous!!!!!
Edit, sorry was drunk and being retarded, out of my character!
nthilavan
booster
Dec 31, 2010
56
SE Portland
okay so now i know its the caller wire thats not getting power..now just gotta find out exactly what is causing it... on another note can anyone tell me were the hose on the bottom of the accordian hose goes too??? mine got busted off will installing new apexi intake..
nthilavan
booster
Dec 31, 2010
56
SE Portland
i need help.. cant figure this problem out. new start new ignition switch.. car will not crank.. the small wire on the starter get no power.. gets a signal at the ignion when i hook the tester up so were would it loose power at??? someone please help. and please dont be a smart @ss.. if you can help i would be great full but if you just tryin to make me look bad dont bother i already look bad enuff beggin for help..
oh yea engine isnt freezed up either... starts when i by pass it but dont know if there is down falls to that so dont wanna do it.
