I recently pulled my engine to change the oil pan and as I was putting everything back together I decided to do the SOGI wastegate mod with 4 washers. Before I did this I was hitting 12lbs of boost with a home made manual boost controller the owner before me installed. Now, my problem is that I am getting no boost and my wideband hits lean. It sounds like fuel cut but I'm not even getting any boost. I checked for boost leaks, but found nothing. Any clue?? I did alot of searching but found nothing like mine. Thanks
