nice surprise when fixing a BHG
themadhatter
760
Vegas
got the head off yesterday and started cleaning up the short block and noticed the pistons looked a little big and the crosshatch in the sleeves looked fresh so i measured them the pistons are a 30 overbore so i call the guy and he tells me the motors been rebuild about 5-6k before i bought it he cheaped out and used a composite gaskit but he had the waste gate shimed so it didn't last
Snotcycle
128
Palo Alto, CA
er...i have stock gasket and shimmed wastegate, will only adding 4psi to the stock boost really put the headgasket in jepoardy?
89Turbo
804
Portland
it all depends how well it was done, did you use ARP Bolts or studs, did you torque them correctly, how hard do you drive you car, do you have any other mods, was the block surfaced, was the head surfaced??
shaeff
Kurt is FTMFW x2!!!!
11
Around
the main reason headgaskets fail is because the stock torque figure of 50 something ft. lbs. is NOT enough, and the bolts loosen up. a stock gasket, ARP hardware torqued to 85ft lbs. and a good tune and you can push more boost.
-shaeff
