Hey Forum,
I am a Supra newbie so don't flame me too hard, ok? I have a 1989 Supra with a 7MGTE that I bought as a project. It doesn't run, but it is in good shape. Anyway, I have sorted through testing all ECU connections and everything seems to be as it should be with one exception. The TPS voltage values are the same whether the throttle is opened or not (about 11v). That being said, can this cause a no spark situation? The engine cranks good and sounds healthy, but no spark. Is there any quick and easy way to "jumper" the igniter to create a spark to the plugs to verify wiring and components?
Thank you in advance for any help provided,
Wayja
Wayja
