Newbie Question... how do you replace the drive belts?
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I realize that this is one of those things that everyone should know how to do, but I'd like to know from people who have done it what the easiest and best ways to replace the belts are. What are the steps, what all has to be removed, etc.?
I know that the fan, clutch, and probably fan shroud have to be removed. What all else has to go? Is it imperative to have a torque wrench when tightening the nuts and bolts after the job is done?
Thanks for any input
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
Yeah, but I probably suck with that. All I can seem to find is it saying "replace belts".
It would be under general maintenance, right? Or am I just not looking in the right place?
LOL my apologies Moy it just sucks and assumes you know how :)
Pwr Steer is 14mm for the tension adjuster side
AC is also 14mm
Alt is 12mm/10mm be careful with the 12mm it's made from silly putty and shears off easily.
You can wiggle the belts in/out without pulling the shroud.
Pwr steer you'll have to lever the pump and tighten.
AC you have to loosen the nut on the tensioner a little then use the vertical 14mm to tension and tighten the nut to lock it.
Alt you loosen the 12mm and use the 10mm nut for tension then tighten the 12mm when done.
Mk3runner
2,033
Nor Cal
It may seem like a pain. But start out slow and get a good look at it. Get good belt tension without going monster ah crap tight on your good
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
I know how to loosen the alt cause I had to replace mine... haha. I've gotten the a/c tensioner bolt loose, but the tensioner was stuck in place, rusted probably... what's the best way to loosen it up without damaging the pulley? I assume going at it from underneath with a ball peen hammer, but I don't really know where I'd hit on it...
AC is also 14mm
