newb boost questions
artmo
97
Portland, Oregon
So i am now at the point where i need to get a boost controller. i have just recently broken in my engine and i want to boooooost. im stuck on what i should get, i am tied between the aem tru boost and the apexi avc-r. im a little confused by the avc-r cause, i was reading somewhere that you should have a fuel upgrade w/ a air fuel tuner at the same time of installation, is this true? or can i just run the avc-r w/o that? i do have plans for fuel upgrades and a safc-II but not anytime soon; strapped for cash. but what is ur opinion on these two products? thanks for the input.
billwert
169
Naylor
If not above 12psi I would prolly go with the AEM TRU Boost. It's an easy unit to use and understand. You said you were strapped for cash and the AEM is not nearly expensive as the Apexi. Think about to whether or not you are going to use the extra features of the AVC-R.
