new wireing harness car wont start/ what plugs are these
thejrman
99
omaha nebraska
well i have a 89 turbo was auto swapped to 5 speed and the harness was hacked to bits when i got the car. i just go a new harness and installed it. well now the car has power but it just makes a little click and dosent crank over.
update
well i bypassed the Neutral safety and it cranked over but my battery is almost dead and i don't hear the fuel pump and it isn't showing any pressure on the gauge on my afpr
fuel pump?
fuel pump relay?
wiring?
what are these plugs
thejrman
99
omaha nebraska
Poodles;1081785 said:
The little sensors with vacuum lines going to them under the intake manifold
ooo my car dosent have those lol
well i hooked up the plug for the starter still dose the same thing
looked at the fuses they look fine
fuel relay???? because i dont hear the fuel pump kick on
thejrman
99
omaha nebraska
thevork;1081842 said:
bad ground?
did you ground the wires near the starter to the chassis?
edit:
also, did you check your fuses yet?
i never removed the grounds
i looked at the fuses last night they looked fine
Kckazdude;1081849 said:
I wouldnt worry about the fuel pump until the starter issue is sorted. If everything is properly connected as it is supposed to be, give this thread a read.
well my friends integra was doing the same thing my car is doing and the main fuel relay was bad
but im going to try that mod
thejrman
99
omaha nebraska
well i bypassed the Neutral safety and it cranked over but my battery was to weak to start it and i don't hear the fuel pump and it isn't showing any pressure on the gauge on my afpr
thejrman
99
omaha nebraska
well im going to replace all the ground in the motor bay and see if that helps
im not getting any fuel pressure when the car is in the on position be for i start it
im going to swap out the fuel relay and if thats not it im going to drop the tank and check the fuel pump
