Okay, got a new (used) turbo. Very happy with the deal, but I want to ensure that I'm not going to do anything bad bolting it on.
It's a Turbonetics bolt-on, internal wastegate, should bolt up to the manifold (with a spacer) and LIPP elbow.
Supporting mods (Either installed, or will be) as follows:
I get some conflicting data on the AFPR, some say "absolutely a must" but I've also heard that just removing the restriction in the "J" tube should be adequate with the stock FPD. Solid reasons why an FPR is a must appreciated, thanks. Not just "the stock system can't keep up with the flow" -- after all, it's the stock system that's carrying the flow from the FP to the fuel rail, so it should certainly be able to handle returning it to the tank, provided that there aren't other restrictions in the line not there to create fuel pressure.
Of course adjustability in fuel pressure gives me some gross A/F tuning capability, which I don't otherwise have. Anyway, I'd like hard data on why this would be needed (or not) as opposed to a "nice to have". It'll go in eventually for sure, but whether that's before or after the turbo upgrade is the debate.
I like to understand mods before I do them, so that I am aware of the consequences, and the other implications of doing them.
Thanks!
- LIPP Elbow, RT downpipe, and Tanabe exhaust. (installed)
- Lexus AFM, PTE 550cc injectors (installed)
- MBC (Will be installed when turbo goes on.) 12-14 PSI manifold pressure is the target.
- Spearco replica IC. (Will be installed ASAP.)
- 2.5" IC piping (to be installed with IC)
- HKS SSQV w/ recirc fitting (ditto)
- Walbro 255lph fuel pump (To be installed ASAP.)
- 12V mod + upgrade to 14AWG wire to handle Walbro fuel pump demands.
- AFPR? (Don't have yet. Recommendations?)
Thanks!
