Hi all, i've just put together a 7mgte with a 57trim ct.
My first question is to do with the stock BOV. i seem to be getting a chirping noise from the turbo when i lift off, and i'm sure this is a bad thing.
How can i check the stock BOV and should i get an aftermarket one? if so which is best for protecting the turbo?
My other question is to do with how much lag to expect from a 57 trim. the boost is standard at the mo as i want to sort out all the issues with the car before i turn up the boost.
i don't see any real pressure until above about 3200rpm, peak is about 6.5 - 7 psi, very little pressure is made in first gear, maybe about 5psi. At about 5500rpm the engine is out off puff, this is more obvious in first and second.
I do still have the stock downpipe on the car.
Any thoughts on this would be great, Many thanks.
