the guy i bought it from said it set a tps code(i can't remeber the code)87supraturbo19 said:spark?fuel? any codes?
jimi87-t said:Did you adjust it? BTW, I started mine once with out the TPS plugged in. It ran, just idled high. So if it's not starting/running, I think you have more problems than just the TPS.
sorrythe supra goddess said:it won't crank as in the engine doesn't even turn or won't crank as in will turn but won't start?
