new toy from aeromotive
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
damn it! If only I would have seen this a few months ago...
oh well, there is no way in hell I'm swapping out the filter I just installed.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
cost for me was 177 going rate not sure over 200 easy
IJ.;1048864 said:
Looked at em when I was speccing my fuel system, expensive tap ;)
I went with a pair of Bosch Motorsports filters, they're cheap and take AN fittings.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
remmber i live in canada so the price will very from canada to the state's
but there so new they have not even shipped them out yet
tsuper92
supra addict
Apr 7, 2005
1,376
mass
nice filter.i allready have there regular one and it would be hard to get at,since it's bolted in the stock filter holder.with my luck i would leave it closed and burn my pump's up
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
damn thats expensive. awesome, but no.
how much is a regular fuel filter?
i dont know if mine has ever been changed...and it probably should be. Tank probably needs cleaned out as well.
can you get good in-line fuel valves separately and install with a filter to mimic this pricey 2-in-one?
NashMan
Aug 5, 2005
4,940
17
Victoria BC
the only reson why i run this is cause i have all brand new fule system sumped a1000 ect
if you have stock then use stock based filter
NashMan
Aug 5, 2005
4,940
17
Victoria BC
reson being is caues you don't have to buy 2 thing's
and some times space is an issue ball vavle and filter can take up some room
and look cluttered
IJ.;1049864 said:
I pay $20 each for the Bosch filters.
Not understanding the need for the tap?
NashMan
Aug 5, 2005
4,940
17
Victoria BC
IJ.;1049889 said:
Yeah but why do you need a tap in the first place on an EFI car?
so when you change your filter you don't make big mess and loose all your fule or have to weight tell you tank is dry to change
jdub
Feb 10, 2006
10,730
Valley of the Sun
If you had to park the car for a while outside, turning it off would be a good way to make sure no one decides to drive it away while you're gone ;)
NashMan
Aug 5, 2005
4,940
17
Victoria BC
naa they burn your pump out trying to start the thing
and yes i thought abouit that as well but that whoudl be bad thing
