So I pulled the trigger on some Tein Street Advance coilovers and am trying to make sure I have everything needed for the install.
My suspension has never been done and I would assume that changing the top hats would be a good idea since the Tein SA use the OEM mounts.
I have seen KYBs for sale, but they specified that it was for converting TEMS to Non-TEMS, I would assume these would still work with the Teins
Any ideas on which OEM type mounts would be best for this install, will the KYBs work with the Teins? I would assume a new front spring insulator would be a good idea? Or so the Teins come with these? I believe they come with the boots right?
Thanks in advance for the help, it's much appreciated.
Here are the part numbers I found from an old thread, can anyone tell me what comes with the Tein Coilovers that I wouldn't need to aquire from this part list?
KYB Uppers: SM5160 (front) (Toyota:48680-14041)
SM5159 (rear) (Toyota: 48750-14011)
Toyota Front Spring Insulators: 48157-14020
KYB Boots: SB101 (front) (Toyota: 48331-14060)
SB107 (rear) (Toyota: 48341-14030)
Nuts and Bolts:
Front upper nut: 90177-12002 x 2
Front upper mount nuts: 90179-10132 x 6
Front lower bolt: 90105-14047 x 2
Front lower washer: 94621-11400 x 2
Front lower nut: 90170-14006 x 2
Rear upper nut: 90177-12002 x 2
Rear upper mount nuts: 90179-08054 x 6
Rear lower bolt: 90119-14018 x 2
Rear lower washer: 90560-14009 x 2
Rear lower nut: 90179-14007 x 2
Nuts and Bolts:
