Thanks guys. Done some work to it but the guy I bought it from did the rest so idk those details but I put a turbo timer, stage 2 clutch masters clutch (kept blowing oem and stage ones), cat back 3.5" exhaust, and wheels. He put upgraded ct26 (don't know what trim or anything about it but it does 17 psi), 264 cams, 3" down pipe, 3" test pipe, fuel cut controller (I know bad Jew Jew), lightweight flywheel, and 5spd swap. Looking to get 550 injectors, pump, fuel regulator, and Lexus afm housing to fix the fuel cut right.
