New to Supra's just a couple of questions
EpicMK3
4
IL
just bought my first supra and was wondering opinions. what is the 7m good for hp wise on stock lower end . . . . . is it poss. to run 1or2jz intake mani on 7m, and maybe if anyone knows where i can find info on fuel cut/boost cut, and what good set up for running a strong head would be thx for the time
carter
"The Ninja"
Nov 1, 2005
743
Ohio
Welcome... Everybody is gonna tell you to search, so you might wanna do that..
there has been a couple people that have used the jz manifolds but your deff gonna have to search for that.
stock Fuel Cut *FC* is around 12psi
stock bottom end is good for 500rwhp or a lil under, but if you want to keep the car for a while, then you might as well rebuilt it.
And one of the first things your gonna want to do before anything else is get a Metal Head Gasket and arp headbolts.
Carter, J.
And Obama FTW!
Dirgle
Conjurer of Boost
Pauma Valley, CA
stock bottom end *FRESH* is good for 500rwhp or a lil under, but if you want to keep the car for a while, then you might as well rebuilt it.
Carter, J.
And Obama FTsocialistW!
Take the time and take care of the basics before you start pushing more hp out of the 7M.
