Hey all,
Figured I would post up a couple of issues and see if anyone had experienced this before. First, I need a Cam Position sensor cover? And it leaks oil, so where is the best place to get this item and the o-ring? Will a dealer be able to get it? Oh, the car is an 89 Supra turbo automatic.
Second, the car is slow. Like, I don't feel the turbo really kicking in, nor do I see more than what appears to be 5 psi of boost. The turbo has very little shaft play side to side or front to back and appears to be in perfect working order. The car also has a new head gasket, ARP head studs, new front and rear main seals and timing belt, as well as a new (used) transmission that shifts nicely. But it's slow. Like, Scion TC pulls away from me in the midrange slow, and he wasn't trying hard. Someone suggested that perhaps my exhaust is restrictive, and it has the factory cats and a cheapo muffler with crimped bends, so maybe this is my issue.
Third, the heat works, but the blower motor doesn't respond to any inputs when I change from low to med to high. The green light only lights occasionally, but most of the time its off.
Any ideas or places to start?
Thanks,
Chris
Thanks,
Chris
