ok so i bought a 89 mk3 turbo came with greddy intercooler and blow off vlave. and the usualy exhaust and intake. when i first got it it had check engine light. had 5 codes on it. i got it down to 1 code, code 22 for coolant temp sensor. it is very hard to start when cold. it starts then stummbels and dies untill it warms up for a few minutes but it runs awsome once warm. my cold start injector switch is broken i can pul the acualy sensor straight out without un doing the nut that holds it down the plastic part is detached from the nut.
so my question is can a bad cold start switch cause a code 22 ? and do my symptoms sound correct for the cold start switch?
thank you
thank you
