new supra for me?
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
ok guys tell me what you think i found an 86.5 supra 5spd white with blue leather tint tems all the options good paint a little rust on one fender about the size of a 50 cent piece good tires 180k miles but has new metal head gasket new plugs all that stuff w/p belts new rad. guy said he washed it one day and now it wont start he replaced a relay it started fine cut it off it wont start but you can jump a wire from the + batt terminal to diagnostics plug and it will start fine no smoke no knock a 60 yr old man owns it and is garage kept passenger window doesnt work possibly switch but he said he would take 700 bucks for it. i think im going to scoop it up and give it a good home it may be na but for that price i could use it for a dd if nothing else and does anyone have any idea about why it wont start unless you use the jumper wire? bad ecu or fuse or what. oh and the leather is a little cracked but still intact.
Mr.SelfDestruct
I build planes... yeah...
May 27, 2005
608
everett, WA
whenever you have two of the same car, and are planning to use one as a DD, and the other as a project/race car, turn the crappier one into the project, that way you wont waste perfectly good extra options on a car where you wont use them.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
oh i see you mean like do a gte swap on the 86.5 and use the other as a dd right. i like that idea but when i get done im going to have like 3 supras.
americanjebus
Mr. Evergreen
wa.
try locking it, and unlocking the driver side door w/ key.
sounds like all your doing is jumping it each time which is what i did to get arround the stock alarm. or fix that relay that got choped off.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
im not sure whats causing this could it be the ecu? lock and unlock the door whats that do? dumb ? i know but i dont get it
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
the car will turn over and over until you jump the wire from batt to diagnostic plug the it will run it also has new alt.
americanjebus
Mr. Evergreen
wa.
nm if it turns over then its something to do w/ ur EFI
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
i talked to the guy tonight he said the relay he changed out was the fuel relay and it started but when he turned it off it wouldnt start again he said he changed the efi fuse and a few other things he ssaid he thinks its either the ecu or possibly the distibutor what else do you guys think it might be?
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
im going to but im going to also buy the other car. i was just wondering if you guys might have any idea as to what else it could be. how much for a mani or adapter to hold the ct26a?
