New Supra Buyer Questions
wolfman_matt
Stocker
May 8, 2008
Apex, NC
How do I check to see if a car I am looking to buy has lsd or abs? Tems is obvious to me. Are there any other options to look for on a 92 N/A?
The site is a wealth of knowledge. Thanks in advance. Matt
shaeff
Kurt is FTMFW x2!!!!
10
Around
ABS, look at the upper left side of the engine bay (standing in front of the car) The ABS unit will be located there if your car is so equipped.
As for LSD, you could simply check the back of the diff housing, it will say LSD right on it, or check the data tag,
Jeff Lange said:
firewall for 86-88, door sill for 89-92). It will read A/TR: XXXX/YYY. X = Axle code, Y = Transmission Type.
Jeff Lange said:
North American Differential Codes:
G284 = 4.30:1 4-pinion 8.0" N/A Diff (no-LSD, USA Only)
G285 = 4.30:1 4-pinion 8.0" N/A Diff (with-LSD)
G315 = 3.91:1 4-pinion 8.0" pre-89 Turbo Diff (with-LSD)
G305 = 3.73:1 4-pinion 8.0" 89+ Turbo Diff (with-LSD)
http://www.supramania.com/forums/showthread.php?t=47729&highlight=codes
wolfman_matt
Stocker
May 8, 2008
Apex, NC
Thanks Shaeff...hopefully tomorrow I'll be back in a Supra after a long hiatus. Matt
