Well a new problem has popped up, i think it is a bad wheel bearing, just thought i would run it up the flag pole to see what other people think,
I hear a high pitched grinding like noise from the front passenger side Wheel, it's not constant and comes and goes, some times worse then others, i have visual inspected it and the hub portion of the brake disk is become discouloured, my guess is from extreme temperatures, the discouleration is all close to the center and there is non on the Disk it self, it does not look as if the caliper is rubbing but something inside (the bearing)
your thoughts?
your thoughts?
