First off the TSRM Most likely will not answer this question and a search result will not help considering I do not know what this second location is. My car is completely drain of oil and coolant so I do not know what this location is.. But as you can see in the picture. I understand the stock oil pressure sensor circle in red is right there. I know the ECU does not require it but does take readings off it as many other members have told me. Because of that I do not want to remove it or have a T fitting to stick on an aftermarket one which to me will do more good and help for me while letting the stock ECU have the stock oil pressure signal still.
My question is the second location I am seeing is block off with a bolt. Is this too an oil port or is it a coolant port? I can not tell for myself because my car is completely drained of oil and coolant so I will not be able to figure this out. I was hoping someone would. If this second location is indeed good for a aftermarket adaptor for an aftermarket oil pressure location I will surely put it to use.
Thanks, Datsrboi
Thanks, Datsrboi
