New member needs help.
iDriftYou
SoCal/805
Hey guys I need some help with my dash. My car is a 5 speed turbo but the dash has a o/d light under the tach, so I'm guessing that the dash is from a auto. My entire dash doesn't work, the only thing that works is the sport suspension, when I switch it back and forth it lights up, everything else is not working. Do you think it's a wiring problem or the dash it's self. I am currently building my 7motor because my old one through a rod so I'm trying to get everything resolved before I put it back together. Any one have some input on this? All help is greatly appreciated.
leftynridge
401
dayton, ohio
It sounds like that you are looking for a turbo gauge cluster anyway. So I would say get a new gauge cluster and hook it up. If it still doesn't work then it could be the wiring. I'm not sure but I think that there are fuses that control it as well. So you may want to check there to.
barkz
363
Afghanistan
he might already have the turbo cluster, he never said he didnt. if you have the boost gauge instead of the volt meter than your good. And yes the gauges run off a fuse. and if NONE of the gauges are working your best bet is the fuse. or if the cluster was switched maybe he never hooked it up?
