New Manifold... Confused,(Pictures)
Failure14
276
Ohio
Ok so i got this manifold from ebay, yes go ahead and flame me for it
but i just needed a quick cheap one due to the fact that mine cracked.
Well it fits perfect but i have no freakin clue what this part right here
bolts too lol?
Any info is much appreciated,
jdub
Feb 10, 2006
10,730
Valley of the Sun
The wastegate. You will not be able to use that manifold with a CT26 or any downpipe for it. Hard to tell, but it looks like a T4 turbo flange.
Failure14
276
Ohio
Ahh that makes sense now, thanks a ton man...
&& yes it is a t4 flange.
kotu100
1,899
Easton, Ma
i dont think you'd wanna use the stock DP on an aftermarket turbo...
oh and as long as you got the 321 stainless, its a decent quality piece.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
It will require a totally custom DP as the turbo sits way back and has to have a very tight radius 90. To run this you will need a lot of custom fab work. Also if it is the same style Ebay manifold as I have worked on you will have to turn the WG flange 90 as the dump goes straight into the wheel well.
Seth
jdub
Feb 10, 2006
10,730
Valley of the Sun
Seth
Yep!
You can replace the WG flange with a V-band to use a Tial type.
