New Lock Cylinder Set Questions
JDMMA70
2,550
Houston
Im having a hell of day right now. However i need to know if Toyota can no longer get Pre89 Lock Cylinder sets will 89+ lock cylinders bolt right in to a Pre89?
Thanks
~JDMMA70
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
90+ is different due to the key.
I have a Set I'll sell to you for CHEAP. The Key is worn but still well useable, but I have the key code (champion will recut you a key using the code for ~10 bucks), and or you can take the cylinders to your local lock smith and for ~20-30 bucks they'll rekey them for your old keys.
They cant get pre 89 sets? They still have the key codes on file so i dont see why they couldnt.
They should fit no prob with the exception of the rear lock being slightly different.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
go for 91+, you can't start those with shaved down popsicle sticks the way you can pre 90's...
should be the same, except for the rear lock, unless you have 89+ taillights..
mkiii-1jz
The Neverending Project..
Denver, CO
One place you might try is T.A.P Recycling in CA. Right after I purchased my car several years ago, I bought a complete set of locks for $75. Locks were in good shape and worked great.
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
86-89 use one key type
90-92 use a different key type
86-88 use one type of hatch cylinder
89-92 use a different type (different tails)
So yes, you can use a newer lock cylinder set in your car, but the hatch cylinder will only work 100% correctly if you are using the newer tails, if not you may have to try to modify it to work.
As for availability of the sets, if anything is still available it will only be in grey and/or shadow grey, all other colours change up (this only really applies to the glove box lock). That being said, I was under the impression (and I quickly checked a few numbers) that all lock sets are obsolete at this point. If you can get one, go for it, because it will be one of the last if you can get it at all.
Why do you even need an entire new set? Individually most cylinders are still available, why not just get the one or two you actually need and get them rekeyed to your code?
Jeff
