MarkIII4Me;2037597 said:Not sure how the term "new" applies here as that injector is pretty beat. Looks like the bottom cap is deformed (melted?). The caps are replaceable however. Even still, once should always clean and flow test used injectors. Even more so when they are received looking like that. Definitely don't use the pictured injector in its current state as it looks like the cap would royal f#ck the flow pattern.
supraguy@aol;2037613 said:Those are 550's? out of what?
tromspert;2037617 said:Not sure, that's what I was told they were. What do you think they are? I know they fit but that's about it.
thesupragod;2037651 said:Then you should be able to order new caps from RC, they should be the same nozzle size if they fit the stock rail.
