New indiglo gauge install and climate control lights
chris89
419
Columbia, MO
I pulled the cluster and the climate control out and i want to install my new gauges and change my climate control lights to blue....also i wanna replace all my gauge lights with brand new ones.....not sure if i should just get white or what..??? I have the reverse indiglo gauges....
help
CPT Furious
Now MAJ FURY!
KDOV
Just be VERY gentle with your needles. It's really not that hard to change your gauges, but getting them to indicate correctly may be a PITA. It took me about 4 tries to get the fuel quantity to indicate correctly. Pretty easy job overall, though.
chris89
419
Columbia, MO
i tapped the oil pressure, it was like 2-3 mm below the Minimum line now i think i F*ed it up also the volts meter.... How do i wire everything and install the gaues....in steps...please
chris89
419
Columbia, MO
OK, got everything all good the gauges work great just my climate control and dash lights don't work. the fuses are all good. it's messed up.
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
gixxer750 said:
I know the feeling....I killed my speedo. It reads 0 when at rest, but it is 20 mph driving
:stickpoke :wtf: Maybe you're going 20mph! LOL! And, if your car is stationary....that would be 0 mph (last time I checked!):aigo: :biglaugh:
SupraMario
I think it was the google
The Farm
any lose wires? when u said u bumped into those two gauges maybe you knocked lose a wire. you could try and pull the climate control out and check back there, im betting thats what it is, if your fuses are good, i bet its one damn wire was knocked off.
chris89
419
Columbia, MO
ok, ill check. I've checked before and it was all plugged in all good. People have said it's the rheostat....whatever that is....I don't know how to fix this...
Suprastic
727
Manitoba
LMK when you change you climate control lights. I'm wanting to do the same thing. Also you don't need to remove your needles and risk misaligning them to put on the new gauges. They slid over top of the original needles and gauges very easily.
