Hi.
So i installed a new HG. Greddy 1.5mm. It was a re-built Head and the block looks like its been recently re-built too (had warranty stamps).
I changed all the intercooler piping to Hard pipes. Put an HKS SSQV. Here is the problem.
1. The car has NO POWER. When you push the gas, at about 1200 RPM the boost kicks in. Hence the car heats up quickly too. You can hear the BOV going off at 2300 RPM. Really frustrating.
The car lags in running.
The BOV (SSQV) is pushing out air when the car is idling. As soon as i push the throttle open s little bit. It closes it self. Then it open to release the air, but remains open for a long time, hence a longer BOV sound.
The car seems like its starving for air, i have no idea why.
I checked the BOV, and its connected to the Vacuum line right. The line come from the right side of the engine bay. I will take pictures and post them tommorow. Just wanted to get this out there to have some ideas.
The mechanic who did the HG has no idea whats going on. I need to somehow make the turbo not come on that soon. Why would it do that ?
2. The car overheat, i guess this is because of the turbo constantly running, changed the thermostat. Put a new cap on radiator. Water pump seems to be working fine. All fans seem ok. There is a little play in the clutch fan but not that much.
Any and all help will be deeply appreciated.
Thanks.
Thanks.
