Update on the car. Here is a few pics. Car has been enjoyed for a few years now. However big new round of upgrades right now.
Mods: NPG MKIII 67mm turbo kit,NPG stainless cat back, NPG front mount intercooler, tial 44mm watsegate, 50mm blow off valve, 550cc injectors, 255lph high pressure intank pump, bosch 044 inline pump, aeromotive fuel regulator, dual feed fuel rail, custom 6 puck feramic clutch from southbend clutches, short throw shifter, tein flex coil over suspension, nitto tires and drag radials , ebc brake pads, brembo front and rear rotors, forged rods, JE 9.25:1 pistons, swain coated pistons, bearings, and combustion chambers ,cnc ported cylinder head, 1mm oversize ferrea undercut valves, comp cams valve springs, custom built titanium retainers, custom grind camshafts, oil system modified, hks cylinder head gasket, arp head studs, arp main and rod bolts, carbon fiber timing cover, carbon fiber wiper cowl , carbon fiber door sills, NX anti lag nitrous system, devils own water injection
Mods being done right now.
Tubular suspension
Megasquirt
larger injectors
new clutch and flywheel. wanna to go auto instead
larger oil cooler
u-joints
solid main subframe bushings
complete poly bushing set
offset front upper control arm bushings
COP
