Anyway, I just did the headgasket job on my car check the cps for proper alignment took the cover for the cams everything aligns. I start the car the engine has this popping noise and the car is running like its missing and when you rev big white smoke coming out of the tail pipe. I check and check that cps even took out the valve cover making sure its aligning properly. check for engine codes only blink 1. Will a blown headgasket foul out a spark plug? If anybody can chime will appreciate it. Also if somebody can look in to their injector colors is white then red then white then red for the connections. I also did compression check most of the cylinders are above 140
