Hey everyone, my name's Sean I'm 18. I drive a black 1988 Supra turbo. Kinda a project vehicle... I've only driven it twice, it has spent the rest of the two months I've owned it broke down... Front main seal then coil pack. The body isnt in the best shape, neither is the interior but I'll work on it.. I'm a dsm guy at heart... I've had two and loved them both.. Figured I'd try something new so I ended up buying one of these... It doesn't have really much in the ways of aftermarket parts but I'll just post up the list the previous owner had
Motor:
.40 Toyota pistons with Toyota rings
New Toyota main and rod bearings
New rod bushings
ARP main and rod bolts
New Toyota water pump
Newer belts
New timing belt and tension spring
New thermostat and radiator cap
New Toyota oil pump
All new seals and gaskets
4 puck clutch w/ new TOB assembly
Fidennza flywheel
Rebuilt master and slave cylinders for clutch
relocated oil cooler
Relocated coolant overflow
Silicone vacuum lines
Head:
3 angle valve job
New Toyota valve seals and springs
2.0 Titan MHG w/ ARP bolts retourqed
NA cam shafts
New heater union and hose
EGR eliminated
A/C eliminated
NGK 1 range colder plugs and wires
Fuel:
255LPH Fuel pump
Aero Adjustable fuel pressure regulator w/gauge
FPD removal kit
cleaned stock 440cc injectors
Turbo: .
Larger front mount
Custom IC pipes. 2.5” steel lower and 2,5” aluminum upper w/ rolled ends and silicone couplers
Turbo XS RFL BOV
Catch can
Electronics:
Autometer EGR Guage
Greddy TT
Dual electric fans
Suspension:
Tokico Illumina 2’s all around w/ new bump stops
Eibach springs all around
Front Greddy STB
Body:
Newer targa seals
Newer front and rear seals for targa
Newer rear hatch seal
Knock sensor rewire
Exhaust:
Titan 3” test pipe
Blitz 3” Nur Spec catback
Here's some pics, I don't really have anything worth seeing but you kinda can get the idea
Motor:
New rod bushings
Newer belts
New Toyota oil pump
Fidennza flywheel
Head:
3 angle valve job
NA cam shafts
EGR eliminated
A/C eliminated
Fuel:
255LPH Fuel pump
FPD removal kit
Turbo: .
Larger front mount
Turbo XS RFL BOV
Catch can
Electronics:
Autometer EGR Guage
Greddy TT
Dual electric fans
Suspension:
Front Greddy STB
Body:
Newer targa seals
Knock sensor rewire
Exhaust:
Titan 3” test pipe
