New from Missouri with a S-Chassis
aled
4
Chesterfield, MO
SupraMania,
My name is Alex, I'm from St. Louis, MO. I'm currently in the process of swapping a 1JZ/R154 into my drift car; 1995 Nissan 240sx.
I've been joining a few Toyota forums to garner community support should I have questions/issues.
Anyways, here's some background info on the car:
This was my 2nd SR. I sought reliability after the 1st one blew up.
This winter, I decided to take on a project I've really been intrigued on doing for quite some time. Originally, I was going to pick up a MX83 Cressida and swap a 1JZ into there. However, I realized it would be much more neat in the S14.
Reasons for choosing this power plant?
- Forged Bottom End
- Inline 6
- R154
Quick Fast Forward....
Very close to completion.
Parts List:
- 1JZGTTE, R154
- ACT Clutch, 3200lb. Pressure Plate
- Driveshaft Shop Chromoly Driveshaft
- Poly/Solid Motor/Trans Mounts
- Griffin Radiator/Samco Hoses/Flex-a-lite 12'' Fans
- Setrab Oil Cooler
- Greddy Oil Filter Relocation Kit
- 4 Core Intercooler
- 60-1 Garrett T3/T4 Hybrid Turbocharger
- Tubular Manifold, Same-Length
- 40MM WasteGate
- Custom DownPipe/DumpPipe
- 680cc Injectors
- Aeromotive Fuel Pressure Regulator
- AN -6 Stainless Steel Fuel Lines
- Inline Walbro 255 fuel pump
Chassis:
- Powered by Max Rear Subframe Risers
- Powered by Max Rear Upper Control Arms
- SPL Traction Arms
- SPL Toe Arms
^Finally, Hard to believe I've been on all OEM Rear Suspension Arms for 2 seasons.
Aero:
- Version Select Type II Aero
- Origin Rear +30MM Overfenders
- Origin Front +30MM Overfenders
- K's Aero Rear Spoiler
- Circuit Sports Clear Headlight Covers
- DMAX Crystal Turn Signals
Electronics/Gizmos:
- AEM EMS
- Apex'i EL II Boost, Oil Temp, Oil Pressure, Water Temp
- AEM UGO Wideband and Gauge
- Defi 5" Tachometer
That's all for now.
Looking forward to learning more and more!
Alex
