New Best Time
lanternman
153
MI
After getting consistant 13.1's this Wednesday, I went back today and finally busted out a 12 :icon_bigg . It was all in the 60ft, I normally get 2.15's, I must have fell into the groove for once. Unfortunately I wasn't able to repeat it the rest of the day, and only a 13.00 was of note. Now it's your turn Dan.
lanternman
153
MI
Sorry, I was so excited to post it up I forgot myself.
Upgraded CT 60-1
K&N Intake
Full 3" exhaust (no cats)
Lex Afm and Denso 550's
~15 psi with 11-11.5 afr (just started tuning it, was as low as 9.5 in some spots before tuning)
Running 275 Nitto DR's at 25psi
I think she's got at least a 12.5 in her without any more work, but It will take a miracle for me to repeat that 60' time. Either that, or a track that's actually prepped. :icon_razz This run was done in the middle of the day, 80+ degrees, so on a cool evening, I should be golden.
Dec 3, 2003
6,653
Canada
Good job :naughty: I think once you get the fuel dialed in your good for mid 12's with ease. MPH will go up some as well. Get that on vid if you can :biglaugh:
What was running next to you?
DUane
lanternman
153
MI
Blue87T(Dan) said:
Tremendous man. Your killing me here. Awesome 60.
You have definitely put the pressure on.
Send me any datalogs that you might have from your runs. shreve_dan@yahoo.com
Thanks, will do. Unfortunately I didn't get that run logged, but I can send you my last 2 runs from Wednesday, basically same setup with worse 60' times.
