Nerve Racking Turbo Timer
LilRedSupra
Soupy
May 8, 2006
198
Louisville, Ky
Here's my problem: After wrecking my NA Supra last summer I bought my friend's Canadian 89' Targa Supra and a Silver Greddy turbo timer was already installed! I double checked (using test light to ignition key cylinder) every connection from the timer harness to the points to where to tap into the factory wiring harness! All was good!!! The timer will NOT count down when the ignition is cut and key out of the ignition cylinder! I don't know if it is something I'm just overlooking or the timer it self that is at fault! Any help would greatly appreciated guys! I think it MIGHT be the timer itself! Not sure!:aigo:
P.S. After wiring my friends SR 20 swapped Silvia ECU/Harness, I wired his Greddy Turbo Timer and it worked perfectly! When I plug my Timer into his Turbo Timer wiring harness it dosent count down either! Weird!
Racefiend
OH, YEAAHH!
Apr 6, 2005
106
Bay Area, CA
I think the answer is pretty obvious, your TT is toast.
