Need wisdom
mtoxracerfss
Boost Addict
Oct 8, 2005
177
Toledo
heres the story, i was driving my 89 supra turbo around one day and when i pulled off of the road and into my driveway, coolant was coming out of my overflow hose....sooo i figured blew my head gasket naturally. Well i just got it back from my mechanic, and he put in an HKS headgasket, valve seals, cam seals, etc. and it is still doing it! The mechanic said i probably have a leak in my radiator somewhere which is causing it to boil due to low pressure...and he told me it looked shot while he was doing the job. He also said that the head gasket didnt appear to have blown at all. The coolant light comes on when i drive approx. 15 minutes....unless i have the heat on full blast....which he says is another sypmtom of a faulty radiator.....what do you guys think? Torqued to 72lbs.....
steve_mk3
5
middletown, NJ
It could just be your radiator cap.
You could have the cooling system pressure tested that would tell you if it was the radiator.
Did you replace the head bolts?
Steve
mtoxracerfss
Boost Addict
Oct 8, 2005
177
Toledo
no i didnt buy ARP's....the car doest smoke out the exhaust either at all if thats any help. Dosnt overheat or gauge jump either, just loses it out the overflow.
mtoxracerfss
Boost Addict
Oct 8, 2005
177
Toledo
The guy that did it has owned a lot of supras and said that the stock bolts work fine as long as you dont torque the hell outta them or overboost your car.
dtoys
Need Job..will travel!!
Sep 22, 2005
11
jersey
word! same thing happened to me (coolant poured out the hose)...i had to replace the radiator.. expensive!
americanjebus
Mr. Evergreen
wa.
expensive................ uh yea costs a billion dollars and you have to shipthe car to japan for a new rad.
or buy one for $100 at radiator.com and have it in 2 days.
dtoys
Sep 22, 2005
11
jersey
american..i stand corrected...how'd they work out for you? reliable?
americanjebus
Mr. Evergreen
wa.
yea i used them like 2 yrs ago when i replaced everything during hg so i dunno if their service changed but ordered an oem and got it by fedex in no joke 2 days and seriously i forget i changed it.
total cost was like $120 shipped.
and its http://www.radiators.com/ i misspelled the first time.
in the end i ended up paying more for the red toyota coolant.
IHI-RHC7
"The Boss"
Oregon
Radiatorworld has a 2 core aluminum race radiator for 270 shipped if you want to go the performance route.
mtoxracerfss
Boost Addict
Oct 8, 2005
177
Toledo
Thanks for your replies. I am going to have it pressure tested first. What do you guys think of the koyo radiators for $100??
