my 89 supra turbo 7mgte has crapped out on me... well i did a compression test and clyinder #3 has 30psi and the rest came out to 90 psi. i know it could be the oil ring thats bad for one or maybe the valve is gone thats making me to lose compression. i have blue smoke coming out of my exhaust when the engine is cold there is no smoke but once it gets warm i have alot of blue smoke comign out. i check all my plugs and there all black where the tip is and only spark plug # 3 where i have 30psi has oil on it. the black sparkplug tip = im running rich i believe ? and this happened to me twice now where my temp gauge has rose almost up to HOT i shut the car off quick and saw coolant all over the floor but no broken hoses or anything the coolant came out from the resivor from the overflow valve and my resvoir was filled and in my raditor it was almost empty.. and in 1st gear when i give it a lil gas i can hear something bubbling sounds like water but im thinking coolant ? or could it be air thats coming into engine ? vacuum leak? can some give me some input could this be a blown headgasket? i dont smell any coolant from my exhaust and wouldnt my sparkplug tips be wet from the coolant coming into my system? thanks guys!
