Need some help with a crank, no start engine.
eighty-7t
chrono on SF
Apr 23, 2005
30
San Jose, CA
car is an 87 5spd turbo.
i recently bought this car and it was diagnosed with a bad wiring harness. i bought a complete one and installed it. still, car cranks over, but does not start. im getting codes 14, 24, and 32. i'll be in antioch, ca till tomorrow if anyone wants to come over and help! =)
can i get some help on where to go from here. i'm getting fuel and spark.
eighty-7t
chrono on SF
Apr 23, 2005
30
San Jose, CA
If you're talking about the grounds on the lower intake manifold, then yes, I connected those.
I replaced the wiring harness with one from another 87.
kotu100
1,899
Easton, Ma
is your HAC plugged in? that would cause your 32
Afm could cause the 24
ECU isnt receiving an ignition signal causing the code 14, does the tach move at all when you crank the car? if not your CPS wiring is most likely the culprit.
