i got my 5spd swap/head gasket change/everything done today. it has been in work for a couple of months. i need it to accelerate properly.
i got it to fire up after i set the ignition timing. it will idle perfectly now. it will not accelerate easily after 3k rpm. but it will make it to 4k if i ease the pedal. and it wont take punching the throttle at idle or in gear.
i have put aftermarket headers, AEM intake, r154 tranny w/SOGI mod, cruise deleted, and egr deleted. i replaced all gaskets with new. all hoses were marked upon removal. double checked the engine timing, and set the ignition timing to 10 degrees. right now it is open headers no catback. there are 2 or 3 vacuum hoses that need to be capped. but i dont think that it will affect this issue.
any help is appreciated. thanks in advance.
mike.
mike.
