Just spent the weekend on the Supra to replace my old leaking oil pump.
Pulled the engine, pulled oil pans, timing components. Replaced oil pump, o-rings, put the pans back on, bolted the tranny back together, dropped the engine back in. I even had time to make a whole new exhaust, and it came out great. I went to crank up the car once everything was done, and to my dismay, the car wouldn't crank.
When I say it won't crank, I mean, BY HAND, it will not turn over. I tried to spin it backwards and it will move a few degrees and then CLUNK. Then spin it forward, and it will spin a few degrees and then CLUNK. What the hell could it be?? I'm running the Aristo 2JZ with auto trans.
Here's EXACTLY how it went:
-Pulled oil pans, timing components, separated trans just enough to pull upper pan, etc.
-Replaced oil pump, timing components, seals, etc.
-Cranked by hand to straighten/tension belt .. turned over fine.
-Pulled a rod cap to check bearings, looked good, put back on to 22ftlb + 90deg (done many times in the past)
-Reinstalled upper oil pan, baffle, pickup, lower pan
-Reinstalled transmission
Now, obviously the part about pulling the rod cap stands out because it's internal. However, I am iffy about the transmission installation. I feel that the torque converter bolts are hitting the splines on the back of the block. That would explain everything. When the transmission was being mated to the block, it kind of went at an angle.. but it went.. it worried me at the moment but then again it mated up and everything seemed fine. Now that I'm thinking about it I'm smacking myself in the head.
The question is.. should I pull the lower oil pan and check the cap? Or is that definitely not it.. and I should just pull the tranny.. ?
Thanks for any help, I could also use a pic.. if anyone has a 2JZ with auto if you could take a pic of the inspection cover so I can see how close the bolts are to the edge of the cover.. I'd appreciate it. My bolts damn near touch the edges of the opening and I feel that's abnormal.
