need some advise
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
samson said:
how do you know that your plugs are bad :1zhelp:
theres lots of ways to tell.
i suggest getting a haynes book and reading it and also check out the tsrm afterwords (its meant for toyota mechanics vs haynes a home mechanic)
either of these are great for general maintenance
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
Depends on what you mean by "bad". You can pull them and see if they are soaked in oil from running to rich and that will eventually make them go bad. You can test the resistance in them or go to autozone or advanced and buy a gap tool. Then see if you need them regapped if they are capable of being regapped. You can see if the electrode on the end is still good and not burnt up. Just somethings to look for. Hope this helps
