Long read... Sorry
Well, I hoped this day would never come but my car developed rod knock about 2 months ago (really minor but getting worse). This car has been with me through better and worse but unfortunately it decided to go at a time where I have absolutely no funding (which is why I've had to drive it around in this condition).
I'm looking at my options which seem to be as follows... I need your advice on both a general and technical level:
1. Get a used 7m from an engine importer ($1200-ish)
I am definitely leaning away from this because I hate the prospect of buying a motor for 1200 bucks, dropping it in, then taking the chance of being in the same damn predicament (rod knock or BHG) a few months down the road because I don't know anything about it's actual condition.
2. Do a full rebuild ($3000+)
To be completely honest, all funding for whatever I do is coming from my dad (as my "college graduation present"... he basically just feels bad for me) so spending this much money doesn't really seem like an option... My original vision for this car was to ride out my motor and build another on the side (full performance build) once I started my career and had extra money... If I were to do any build right now it would be a "back to stock" build and that just seems like a waste of money when thinking about my long term goals. (On the short term I am looking to chill for a few years and maybe upgrade the ct26 to be somewhere around 350hp... On the long term, which is many years down the road, I'd like to aim for 500+)
3. Replace only what I "need to replace"(Hopefully under $2000)
I was also thinking about just fixing what "NEEDS" to be fixed which I'm thinking is this... and please let me know if i am missing anything (this would be the major technical aspect I need advice on):
-doing whatever machine work needed
-replacing all engine seals/gaskets
-replacing the rod bearings
-replacing piston rings
-replacing individual rods (if needed)
-replacing individual pistons (if needed)
-replacing the crank (if needed)
-metal head gasket
-arp head studs (have these in the current setup)
Considering my situation (my budget and the fact that my goal for this motor is only 350hp)... What do you think my best option would be?
On a side note... I will be doing ALL of this work on my own obviously aside from the machine work (I'm not feeling ballsy enough put the bottom end back together on my own but I'd certainly take it apart)... I've owned and worked on this car for 4 years now so I know the motor pretty damn well.
In the end, I just want a setup that will be reliable for a couple of years until i get my stuff together and can afford a daily driver and to build my dream motor.
Thanks,
Chris Cramer
p.s. Inevitably someone will want to say "get rid of the car... or go 1j"... So, please notice that none of those variables are included in my 3 options. ha.
-metal head gasket
Thanks,
Chris Cramer
