ok I'm really stuck, I've been searching for 3 weeks now and not having any luck. Printed off lots and lots of 1JZ wiring diagrams went through the pile and kept what I thought I needed. Here is the problem, I have a front clip from a JZX90 (Chaser,Mark II...) I have the complete wiring harness pulled from the clip and started working on dumping all the ABS and TRC crap that I don't need. I go to start tracing the wires on the on the ECU and find that none of the pin outs on the P16 or P28 match up with any of the PINOUT diagrams that I have. I've been banging my head on this for 4 days now and need to know if I just retarded or I really don't have the pinouts for the right ECU. Everything that I'm finding on other forums are for the Supra (JZA70) or something else or say use the Jzz30 diagram for the JZX90. Yeah, not so much. My Goal here is to have the thing in Running Mock-up for my 30th B-Day Sept. 3rd. At this point it's not going to happen, but I want it to Fire up by then.
ECU Pic
ECU Pic 2
Main diagrams that I started with were:
http://mkii-supra.com/images/images/Supra/Phase2-3/Wiring/jzz309gp.jpg
http://mkii-supra.com/images/images/Supra/Phase2-3/Wiring/1JZGTE__JZZ30__pinouts-12286-76381.pdf
http://http://mkii-supra.com/images/images/Supra/Phase2-3/Wiring/JZZ30-Large.pdf
All the Wiring diagrams that I have are here, I haven't gone and re-named them correctly but these were found all over the net someone else may benefit from them:
Damn it:
ECU Pic
ECU Pic 2
Damn it:
