ok so im doing a conversion/build im dropping a 88 7mgte with ecu/harness into my 89 NA. im having the motor hotbathed and rebuilt with eagle rods and JE pistons(everything machined by noonan performance machining). head rebuilt by toyota, stock exhaust manifold with stock ct-26 with no shaft play, true 3" down pipe, 3" test pipe, 3" cat-back exhaust (full turbo back exhaust costum fab by Acceleraded proformance). hks SSBOV, turbosmart manual boost controller, HKS super mega flow intake. Radiator hardpipe kit, stock cams/cam gears, greddy timing belt, ngk wires, eletric radiator fans, apexi SAFC, AEM wideband, autometer boost gauge. NA rear diff, NA tranny, clutch masters stage 2 clutch. hopefully a vpc off ebay not sure if im gonna win the bid yet. what do you guys think of the build, any ideas on potential? how much boost should i run off the bat? any ideas/comments/conserns much appricaited. keep in mind all parts max out my current budget.
