Need Opinions: Is this going to cause a problem down the road. (Valve Clearances)
JDMMA70
2,550
Houston
What it sounds like to me is my valves are ticking, i know i tighten my cam bearing caps to spec cause i did it. So its been running like this for about 1500 miles now, since i last posted about this back in July. So obviously i need to check and re-shim but at the same time shims arent cheap, and im currently out of work looking for a job. So my question is, are there any short or long term effects driving the car as is? Video at the bottom
http://smg.photobucket.com/albums/v436/Cobra281s/?action=view&current=MOV00238.flv
Thanks for your time.
~JDMMA70
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
I couldn't get the vid because im on my sidekick. You'll wear your parts out much faster if there not within spec.
Also when I shimmed mine I basically traded with toyota. They had a big box of shims I brought in 10, got the 10 I needed and said good day.
