need more 1J help
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
well i got the cooling system fixed and the brakes bled and the master cylinder changed.....now my breaks dont work. i dunno if the brakelight box is bad or what....fuse is fine....
and i guess it fouled out the plugs...already....like 2 miles on the plugs and they are dead WTF???
it idles on like 4 cylinders and revs clean all the way to 6500 it revs smooth, but once it builds any kind of boost it bucks and runs like ass and breaks up BAD!! why in the hell would they be fouled already>??? something still wrong with the knock sensor wiring and its causing it to dump fuel?? i know at idle it pours black smoke. its completely stock with open DP...
BTW plugs are gapped at .028
The Reaper
Jan 10, 2006
1,909
Florida
well the first couple times it ran smooth no problems
but the first time i drove it and boosted on it its started missing and breaking up BAD
im running the copper NGKs 6097's or whatever they are...
The Reaper
Jan 10, 2006
1,909
Florida
yea its completely stock except some gay greddy Airinx foam filter that came with it
we think we might know what it is.
i built boost back when it was running fine and it hit FC and after that it started sucking so we're thinking i blew off the Vac line leading to the map sensor
Sounds kind of like my car, but I know mine is because it's running way too rich. Maybe it is just a vacuum line, but I don't know why that would foul out your plugs so quick. Aaron and I wrapped my coilpacks, because they all had a crack in them. I just wrapped them with electrical tape. You may want to check that as well if it's missfiring at all. Good luck and keep us posted........lol
The Reaper
Jan 10, 2006
1,909
Florida
well it wasn't miss firing at all until i hit full boost and then FC
so the plugs might not even be fouled its just an unplugged MAP sensor thats causing the shittyness
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
Well what i would of done is check them when you got home, and then ask.
We dont know what your 1jz is like. You need to dig into it.
My suggestion, Check your plugs. Then check the coil packs, Do a vac line sweep and check all of your IC piping.
The Reaper
Jan 10, 2006
1,909
Florida
im checking the map sensor before i do anything else
im like 99% positive thats whats wrong
and i dont have the internet at home thats why i didn't wait and it needs to be running ASAP can't wait ANOTHER night for a response.
The Reaper
Jan 10, 2006
1,909
Florida
its not a boost leak
like i said it ran fine the first two pulls no problems then boom it happens
i have tbolt clamps on most of the pipes im sure its the map sensor
