I recently changed the fan clutch and the electric fan of my supra. The old fan was different cuz it has 13 blades and the original only 7 blades. I don't know but the original makes my supra overheats.
if you did what i think you did, then you basically took off the turbo clutch fan, (10 blades i believe) and put on a non-turbo clutch fan (7 blades). that will make your car overheat. put the stock turbo one back on, and make sure the clutch in it works well.
