Need help
Status
Not open for further replies.
splitzhail89
Banned: Scammer, liar, cheat and thief
Jan 11, 2006
Nampa, Id
Hello, last week i asked about a question about not getting spark or a signal to the injector clips. I figured out one problem, and now i have spark, but can not figure out why i still dont have a signal to the clips on the injectors, which is causing them not to fire. I am wondering if i have to have the cold start injector hooked up, cuase i went to a front facing intake manifold in my build, and it doesnt have a cold start injector spot, so i no loner have one on the car. Give me some information about our fuel relay systems. I really need to figure out my problem. Thanks alot.
-Adam
Bishop92t
773
USA
www.ma70.com
No the car does not need the cold start injector hooked up in any way shape or form unless you're in extremely cold weather (talking below 0F). You don't even need the cold start injector temperature time switch hooked up.
splitzhail89
Jan 11, 2006
Nampa, Id
well thanks for answering that question, but i still have no signal to the injector clips, could it be the computer, or fuel relay?
-Adam
Bishop92t
773
USA
www.ma70.com
Could be either. Use the TSRM to trace down your problem further. Double check your ECU grounds on the manifold, check for codes, etc.
Status
