I just did a head gasket job and changed hoses in the process. Now the car doesn't want to run right. Sometimes when i start it wants to idle around 400-500 rpms and when you give it gas it will maybe goto 1500 if im lucky and try and dye out if your pumping it. Then sometimes when it starts it will idle about 800 then when it starts warming up the idle will goto about 1800 and when the throttle is fully open it will only hit 2900 rpms. I also keep getting engines codes 31 (air flow meter) on both start ups and 41 which is and throtle position sensor and i only get that on the second type start up. There is also a strong smell of unbrunt gas coming from the exhaust.
I have checked the wiring on both the air flow sensor and the tps. Set the tps up to the toyota manual the feel guage ohms stuff.
Possible the cps is set wrong? Timing off? any help is apperciated
