:1zhelp:I got my 90t, found the airbag wires were cut in the steering column, along with cruise control/horn. Got the missing parts, put it back together, but was too scared to plug the airbag back in. Must've been cut for a reason. Decided to ask the service dept about it while I was picking up parts at the toyota dealer. (Saturday fun - clean up your supra, drive through the toyota dealership lot and watch all the customers and staff STARE..) So I was talking to one of the mechanics there, and although they were very busy, agreed to take a peek at the car (being females helps here, sorry guys!). So I pulled it in and immediately two more mechanics half my age pop over (depressing!) and are ogling the car. The first mechanic quickly discovers the DS front fender had been replaced, and both front airbag sensors up front are missing. Found the wires that had been cut and taped up. He shook his head and said it would be alot of time and money ($99 per hour!). He also noted that the airbag light doesn't come on when the key is turned. He took a jumper wire to a little box under the hood (excuse me if I get too technical here) and he couldn't cause the airbag light to come on. He felt the the ECU was malfunctioning.
First of all, is this guy full of *()&^ about the ECU? I can get all the parts and take a crack at installing it all, and have the dealer go over it, test it and plug it in. However, I did some searches on here and some think the airbag isn't worth the trouble. My Toyota manual says never install used airbag sensors/wiring, suggests replacing all airbag wiring if the car has been in a wreck. I need some opinions here! I know airbags save lives, so how can I put a price on that?
