i just need a idea on what my timing should be set at. also what is the max boost psi i can run. right now my timing is at stock 12 degrees. fuel psi is at 25psi because i have a aeromotive fpr that raises psi with boost. i have all bolt on upgrades 2.5 intercooler pipes. driftmotion intercooler. 255 fuel pump. 550s. full 3" exaust. wide band. 57/58 precision turbo and lex afm with screw backed out all of the way. i pretty much know how to use the safc but if you guys can give me a good starting point with timing. max boost and lo and hi throttle % on the safc i can tune from there thanks.
